CaK Sun (20101111)
CaK Sun (20101111)
David » 2010-11-21, 00:15
A very lazy low magnification shot of the sun with Lunt Calcium K module on APM 80/480 refractor with DMK41 camera. Despite the fact that it is a routine shot, the sun still reveals its ever-changing beauty.
In a CaK shot, the dark spots are sunspots. The picture can be viewed as a map of magnetic field strength, with the lighter areas being region of stronger magnetic field.
Re: CaK Sun (20101111)
文章社長 » 2010-11-21, 11:05
usually how long it takes for visible changes on the surface, if I want to create animation of this image scale? :roll:
文章Lewis » 2010-11-21, 13:52
社長 寫:usually how long it takes for visible changes on the surface, if I want to create animation of this image scale? :roll:
Interesting, I also want to know. Normally, the sunspot can stand for about two weeks.
I found one animation in youtube.
http://www.youtube.com/watch?v=T0alRDff8Do&feature=related
It seems that you can take an animation at South/North pole.
最後由 Lewis 於 2010-11-21, 13:57 編輯,總共編輯了 1 次。
文章universe24 » 2010-11-21, 13:57
Any references about your quote that "map of magnetic field strength"? Interested to know more...
What I understand so far is CaK feature very sensitive to temperature changes...
文章David » 2010-11-21, 15:35
universe24 寫:Any references about your quote that "map of magnetic field strength"? Interested to know more...
I am no expert in solar research, of course. I would be interested to know more as well. Here is a reference:
http://solar.physics.montana.edu/YPOP/C ... lcium.html
