FLI Cameras - 星河科研社代理
社長 » 2011-03-11, 17:31
星河科研社獲美國FLI Cameras邀請成為地區代理,對相關產品有興趣同好可聯絡本社諮詢進一步資料:
http://www.astro.hk/services_18.html
http://www.flicamera.com/index.html
其中Mircoline、Proline、Atlas Focuser等備受多國天文愛好者推薦。
以下引述FLI Cameras提供產品訊息:
Some examples of our products -
FLI was the first astronomical camera company to introduce the very popular KAF-8300 sensor and the ML8300-45 is considered to be the best camera that uses this sensor. The cameras cooling is -60 deg C below ambient and download speeds are remarkably fast – only 1.5 seconds for a full frame 16-bit image. The camera window features AR coatings with less than 0.004 reflectance.
Our Atlas focuser is the ultimate in repeatability, weight bearing capacity and resolution. It has 105,000 steps of movement over a 0.35” range of travel. This was voted Sky and Telescope’s Hot Product of 2011.
The ProLine PL16803 downloads in 3 seconds, cools to -55 deg C with standard cooling (lower with liquid cooling) and has two separate A/D converters to maximize performance. This is the finest available KAF-16803 based camera available.
The new CenterLine CFW has two internal carousels and motors, a centralized aperture so that the weight is evenly distributed around the filter wheels connection to the camera.
ProLine ~ 60 watts with a 4 amp 50ms pulse opening for the 65mm shutter, .2 amps to hold the shutter open. This is with the TEC at 100%
MicroLine ~ 50 watts with a 4 amp 50ms pulse opening for the 65mm shutter, .2 amps to hold the shutter open. This is with the TEC at 100%
The primary difference is the cooling improvements in the ProLine plus the ability to run a color filter wheel and focuser through the ProLine body using our short cable kit. 12v power and USB connections are available on the ProLine body. This allows a complete system to run with only one power cable and one USB cable.
The other difference is weight - the ProLine is 5.5 lbs and the MicroLine is 2.25 lbs. Finally the ProLine has two separate A/D converters for the ultimate in optimized low speed and high speed performance.
The ProLine body also seals all electrical PCBs from the environment - dusty and humid conditions will never reach the ProLine PCBs.
Re: FLI Cameras
文章Nebulas » 2011-03-23, 12:45
今年才开始对CCD有所关注,MicroLine 很像 映美精 的样子,不知道这几款设备上市的预售价格是几何。
Re: FLI Cameras
文章Nebulas » 2011-03-23, 12:54
Re: FLI Cameras
文章社長 » 2011-03-23, 15:39
microline也比映美精大得多,重1.1公斤水平。
價格和同晶片的SBIG相若吧,但冷凍效果特佳及下載速度快得多,按Cloudynights上的經驗分享,若用STL11000M拍的極暗星雲,有可能隠沒在訊噪中,用FLI調一下就可出來。
Re: FLI Cameras - 星河科研社代理
文章universe24 » 2011-03-29, 18:01
FLI的相机出名下载速度快,请问社长,哪款的FLI相机下载速度最快而CCD size又最大呢?
不知道是否可以类似DMK那样的下载速率?有5fps也已经很好了,可以弄一个拍摄太阳....hehehe。 :D
正在瀏覽這個版面的使用者:沒有註冊會員 和 79 位訪客
