Astrocafe 優惠 - Sky Watcher AZ4 經緯台
社長 » 2010-02-11, 20:21
星河科研社剛引進一批Sky Watcher AZ4經緯台,並為Astrocafe會員提供優惠,數量有限,售完即止。有興趣會員需以Astrocafe登記電郵發至 admin@astrocafe.hk 訂購,售完即止。
AZ4經緯台堅固實用,可承托150口徑望遠鏡,配合大面積Telon軸承及阻力調節,可讓望遠鏡運轉流暢之餘,又能於微風環境下抑制振動,適合中低倍天文觀測。
此經緯台適合承載各中小口徑天文望遠鏡,作個人、小組天文觀測、推行路邊天文活動等。
原價 港幣1580 / 會員優惠 港幣1280
Now Serving Optics on the Rock. (Neither shaken nor stirred)
The AZ4 (the Rock) mount is a true rock-star. It performs like a champ dampening vibrations so they don't compromise your viewing. It will hold steady in a modest breeze, and won't "shake, rattle and roll" at the slightest touch like less capable mounts. The AZ4 manual mount is servable for small aperture telescopes up to 6", spotting scopes, cameras, video cameras. The AZ4 is perfect for serious Casual Observing. While the observing experience starts with consideration of an appropriate optical system, the telescope's optical mounting platform comes in a close second in importance.
The telescope's mount can make, or break the perceived quality of the viewing experience, regardless of the optical system chosen for use. The superbly designed Sky-Watcher AZ4 mount is remarkably portable with heavy-duty, yet relatively lightweight construction - a veritable paragon of stability - perfect for demanding terrestrial and astronomical applications.
A mount's stability and ease-of-operation during the process of viewing stationary terrestrial or moving sky objects can make the experience a consistently enjoyable pastime, or render it perhaps momentarily brilliant, but generally frustrating as images appear to dance around uncontrollably in the eyepiece in a breeze, or at the slightest touch. Mechanical stability and fluid tracking are the keys to mount quality.
The high-performance Sky-Watcher AZ4 mount excels admirably in both these important attributes. The Sky-Watcher AZ4 pan-handle mechanical tracking motions about both axes glide on large thrust-bearing surfaces lubricated by industrial-standard Teflon bearings producing smooth, fluid motion. Control knobs adjust the mount of drag (stricture) to ensure ease of movement without loss of precision.
The mount and tripod head are constructed of rigid, cast aluminum. The tripod are sturdy, light-weight aluminum (AZ4-LJ1). The AZ4's altazimuth design also adds to the mount's stability as the center of gravity is directly over the tripod.
Re: Astrocafe 優惠 - Sky Watcher AZ4 經緯台
文章小李 » 2010-02-12, 10:21
I conform order 1 set
小李
文章: 61
註冊時間: 2010-02-02, 16:05
來自: 北海 馬來西亞
文章社長 » 2010-02-12, 11:38
小李 寫:I conform order 1 set
Dr. Lee, payment received, thanks and will ship to you this afternoon 8-)
look forward to seeing more deep sky images from you Equinox 120.... :P
文章小李 » 2010-02-12, 22:30
Thank you :) 社長.
yes coming soon.......... ;) ;) ;) ;) ;) ;) ;) ;)
小李
文章: 61
來自: 北海 馬來西亞
文章社長 » 2010-02-12, 23:45
小李 寫:Thank you :) 社長.
Dr Lee 在檳城那面,有機會能開個帖子,介紹一下馬來西亞那面的理想觀星地點嗎? 說不定將來會組織一下過來 ;)
我們很快會有一套Digital STARLAB供應過來,有可能有機會見面。
之前已為Petrosains Science Centre供應了兩套星象館系統,也和你們國立天文館Planetarium Negara的女館長稔熟,08年過來時她還帶我們吃小吃呢。
文章小李 » 2010-02-17, 10:52
大家早 !! 新年快樂 !! 今早才來診所 :P .
社長 ~ 檳城是有幾處觀星地點, 可是光害是點晒利!! 在島南端觀測南緯度還不錯喔 :roll:
有機會來檳城旅遊兼獵星, 我來當導遊 :lol: :lol: :lol: :lol: :lol:
還有一處觀星地點是在 Pulau Langkawi 浮羅交怡島, 在網上搜尋到有天文台. 有十幾年沒去過島上,想必發展到很好 !!!
恭喜 ! 恭喜 !
小李
文章: 61
來自: 北海 馬來西亞
文章社長 » 2010-02-17, 17:26
祝Dr Lee開工大吉 :lol:
我們會有機會一起去獵星的 :P
文章小李 » 2010-02-19, 09:54
社長~
昨天收到AZ4了, 中心點很實穩 , 不錯用 !!! :) :) :) :)
謝謝 ;) ;)
小李
文章: 61
來自: 北海 馬來西亞
文章社長 » 2010-02-20, 01:14
小李 寫:社長~
謝謝 ;) ;)
若不是中國新年假期,應會快一點到的....
這套AZ4我選用平宜一點及輕一點的鋁腳,若要再穏一點,可以改用HEQ5 Pro及EQ3 Pro的鋼腳的 ;)
文章社長 » 2012-07-04, 10:40
這腳架用作承載大雙筒鏡:
"the mount is surprisingly very stable.It’s very solid-made."
http://digiborg.wordpress.com/2012/07/0 ... 5sd-binos/
