Lunt Solar System 一系列新產品
社長 » 2015-08-04, 11:27
Lunt are pleased to announce the next run of LS230T/B3400/PT Solar Systems.
見之前香港的LS230T派對 http://www.astrocafe.hk/viewtopic.php?f=14&t=3813
This run will be limited to 10 instruments. However, we are excited to be offering these systems as the Double Stack version with dual USB/PC Pressure Tune control.
Specifications:
Objective: IR coated (Energy Rejection) 230mm doublet optimized at 656nm
f/ratio: 7
Etalon 1: Internal un-obstructed 80mm pressure tuned.
Etalon 2: Internal un-obstructed 80mm pressure tuned.
Blocking Filter: B3400 internal mount
Bandwidth: <0.5 Angstroms at 656.28nm
Pressure tune control: Computer control, dual support.
Focuser: Feather Touch
Mounting: Tube rings and mounting plate included
Terms:
MAP: US$29,995.00
Delivery: 16 weeks ARO.
Objective and OTA assemblies are in stock at Lunt Solar.
80mm Etalon glass is currently in production.
Re: Lunt Solar System 一系列新產品
文章社長 » 2015-08-04, 11:36
Lunt Solar Systems are proud to announce the new SUNocular-mini (TM) Solar Binoculars.
The Lunt 6 x 30 White Light SUNoculars-mini..
With this utra-pocket sized instrument you can view and safely study Eclipses, Planetary Transits, and Sun Spot activity/magnetic storms.
Compact, Lunt SUNoculars-mini's have internal fully dense white light filters making Solar observation 100% safe.
These internal filters are placed immediately after the objective lens protecting them from the elements.
The light of the Sun is reduced to a comfortable 1x10-5% transmission and all ultra-violet and infrared components are completely and safely blocked.
Lunt SUNoculars-mini are manufactured to the same standards of safety typical to the entire family of Lunt Solar products - the premier manufacturer of Solar telescopes and filters.
SUNocular-mini's have individual eyepiece adjustment designed by Lunt Solar which allows for the maintaining of collimation while focusing.
IPD adjustment does not effect collimation.
Specifications:
Filter Type: Internal Dye Filter (non coated. pinhole free) CE certified.
Prism Type: Roof
Magnification: 6x
Objective Aperture: 30mm
IPD Adjust: 56-71mm
Eye Relief: ~ 9.0mm
Eyecups: Fixed
Transmission: OD-5
Focus Type: Individual Eyepiece
Tripod Socket: None
Color: Yellow, Red, Blue
Weight: <10 ozs
Ages: 13+ (parental supervision recommended)
What's in the Blister Pack:
SUNoculars-mini
Strap
1 year Warranty
Terms:
MAP: US$29.95
Part Numbers:
SUNocular (Red): 465
SUNocular (Blue): 466
SUNocular (Yellow): 467
Availability:
Red, Blue, and Yellow are currently pre-order with about 10-12 week delivery.
Please feel free to contact me with any questions or comments.
文章社長 » 2015-08-04, 11:38
Lunt Solar Systems are proud to announce the new SUNocular (TM) Solar Binoculars.
The Lunt 8 x 32 White Light SUNoculars..
With this pocket sized instrument you can view and safely study Eclipses, Planetary Transits, and Sun Spot activity/magnetic storms.
Compact, Lunt SUNoculars have a front mounted fully dense white light glass filters making Solar observation 100% safe.
These front filters are precision polished to ensure the highest level of viewing quality.
Lunt SUNoculars are manufactured to the same standards of safety typical to the entire family of Lunt Solar products - the premier manufacturer of Solar telescopes and filters.
Specifications:
Prism Type: Porro
Magnification: 8x
Objective Aperture: 32mm
Eye Relief: 13.6mm
Eyecups: Adjustable
Transmission: OD-5
Focus Type: Center
Tripod Socket: None
Color: Black, Yellow, Red, Blue
Weight: 18 ozs
What's in the box:
SUNoculars
Soft Case
Strap
Lens Caps
Cleaning Cloth
1 year Warranty
Terms:
MAP: US$129.00
Part Numbers:
SUNocular (Black): 485
SUNocular (Red): 486
SUNocular (Blue): 487
SUNocular (Yellow): 488
Availability:
Black version is currently in stock at Lunt. (subject to stock).
Red, Blue, and Yellow are currently pre-order with about 8 week delivery.
正在瀏覽這個版面的使用者:沒有註冊會員 和 79 位訪客
