http://www.daystarfilters.com/
稍後公佈更多詳情。
mwtse 寫:Refractors only?
David 寫:mwtse 寫:Refractors only?
I suggest you buy a big refractor (>9 inch) as an accessory to this eyepiece. Then you can beat this beast:
viewtopic.php?f=14&t=3813&p=24510#p24510
社長 寫:mwtse 寫:Refractors only?
反射/折射射因為光線要在望遠鏡管內來回反射,又貼近管壁,的確很受氣流干擾,影響影像質量。
另外也要考慮ERF的問題。
mwtse 寫:還以為是不同波長的光折射後聚焦在不同位置、不會出現散熱問題。
Raymond TSE 寫:Is it possible to stack Quark Ha eyepiece to existing Lunt 152 and what would be the result ?
Raymond Tse
Raymond TSE 寫:Any information whether the the heating circuit inside the Quark is :-
1. a single stage (ie just heating up and let it cool down naturally/passively. This process is slow); or
2. dual phase temperature control (ie heating up and then use electric TEC to cool it down. This would be faster).
When it takes 5-10 min such a long tme to heat the etalon to reach on-band/variation of each 0.1A, I guess it may just be single stage heating/passive cooling. But Savio might check with Daystar.
Further, when handphone 5V 1A is not to be used for Quark, why not change to 12V for faster on-band heating/each adjustment of 0.1A.
Expecting Quark II version with faster heating/cooling and may be 3x (instead of 4.2x) teleconcentric.
Raymond
Raymond
Raymond TSE 寫:Daystar has made a good point on seeing which means most of the time the seeing may not support larger aperture beyond 150mm.
正在瀏覽這個版面的使用者:沒有註冊會員 和 98 位訪客
