Window 7 環境下的映美精相機設定
社長 » 2010-06-02, 12:18
有用戶反映轉用Window 7視窗後,映美精相機不能設定,主要是驅動程式要修定。生產商回覆如下:
Our Astronomy Cameras already support with windows7(32/64bit) but you must upgrade to our newest driver from our following website which you can download our 1394/USB/GigE camera driver and IC Capture.AS for new OS-Win7 in advance.
Please check for your reference.
http://www.astronomycameras.com/en/products/software/
Re: Window 7 環境下的映美精相機設定
文章Lewis » 2010-06-02, 20:28
I just also installed my Meade LPI into my new Netbook (Windows7) so that I can reduce the total weight of my equipment.
It seems that it's O.K.
文章David » 2010-06-03, 08:10
作一些補充:
我的相機不是GigE,所以下列驅動程式不適用:
http://www.astronomycameras.com/en/prod ... dmgigetis/
Firewire相機的驅動程式:
http://www.astronomycameras.com/en/prod ... dmdcamtis/
USB相機的驅動程式:
http://www.astronomycameras.com/en/prod ... uvccamtis/
文章社長 » 2010-06-03, 10:44
Thanks David for your input :P
