适宜于小型天文台使用的赤道仪—Paramount ME
Nebulas » 2010-05-21, 17:07
The Paramount ME™ Robotic Telescope System features a German equatorial mount with research-grade 11-inch right ascension gears that provide unsurpassed tracking performance. Astronomers equipped with a Paramount ME are defining new levels of reliability, productivity and performance.
Hefting up to 68 kg (150 lbs) of astronomical equipment, and designed for uninterrupted operation, the Paramount ME can be used as a remote or Internet Astronomy™ solution. Through advanced CNC construction, it is “field portable” at 29.5 kg (68 lbs). The system includes the Bisque Observatory Software Suite (TheSky6™ Professional Edition, CCDSoft™, TPoint™ and ProTrack™, Orchestrate™, and Internet Astronomy™ Software Client and Server applications) as well as the Bisque TCS™ dual-axis DC servomotor control system with USB and serial interface, and AutoHome™ start-up.
The Paramount ME is built for the digital age, featuring integrated telescope and CCD camera control, unattended start-up and automated operation, 7 arcseconds or less peak-to-peak periodic error before correction, and precision guided or unguided tracking (using TPoint and ProTrack™). The result is unsurpassed image quality and observatory performance.
Minimum System Requirements
The following computer, software and hardware components are required to operate the Paramount ME.
Computer and Operating System
Any computer capable of running Windows XP (Home Edition, Professional Edition, Tablet Edition) or later and TheSky6 Professional Edition or later).
In general, Software Bisque does not recommend controlling the Paramount ME with outdated, antiquated operating systems such as Window 95, Windows 98, Windows ME, Windows NT.
Any Windows Mobile Device capable of operating TheSky Pocket Edition.
Serial/USB/Bluetooth Communications Interface
The Paramount ME can communicate with a personal computer or Windows Mobile Device using either a native RS232 serial port, a native USB port, USB to serial adaptor or via wireless Bluetooth.
Native USB port (PCMCIA-to-USB adaptors are not supported).
A standard RS232 serial port.
A compatible USB to Serial adaptor.
Any wireless Bluetooth device (requires TheSky6 Professional Edition version 6.00.0
Software
TheSky6 Professional Edition or later (included with the Paramount ME).
TheSky Pocket Edition (software and Windows Mobile Device sold separately).
Hardware
* Paramount ME-compatible optical tube assembly (OTA).
Suitable pier.
好像来自科罗拉多州,在大峡谷上日暮下,用Paramount赤道仪的景象一定很壮观——配合峡谷的红色调。当然在Αyers Rock上也能表现同样的艳丽感。
配合 Sky 6.0 Pro 以上的星图软件。 7角秒的精度。
这款赤道仪的强悍,我想很多人可以从社长之前的图片和报告中看到。
Re: 适宜于小型天文台使用的赤道仪—Paramount ME
文章社長 » 2010-05-21, 18:45
對,派拉蒙來自科羅拉多州,很慚愧的,個人第一次踏上4000米以上高峰,就是那裡的Pikes Peak,而非在中國土地上。
我沒讀萬本書,但有機會走多幾里路,特別是有幸於08底走進派拉蒙的總部,跟Bisque的四位兄弟及老爸見面,學習派拉蒙的開發理念,製作工序等,也即場訂了一台回來。
我可以說,派拉蒙赤道儀是一台很獨特的赤道儀,集美國頂尖的電子、機械、軟件加工及操控精華。有機會稍後發表那個旅程紀實,也有一些其他的工厰如Sirius Observatories等。
文章Nebulas » 2010-05-21, 18:47
嘿嘿,等有机会来香港,一定来看看社长的这架高技术含量的神器。
文章社長 » 2010-05-21, 19:32
派拉蒙赤道儀是市面上少數能負重比自重數倍的赤道儀,主要原因是每一台派拉蒙是花80機器小時,把100公斤T6061鋁材加工,去蕪存菁的只淨下必要的結構,造出一台30公斤不足的赤道儀,但David Levy等是用他來承200公斤望遠鏡的,那負/重比是1:6之鉅。
要知道,論鋁材強度,砂模鑄鋁 < 壓鑄 < CNC加工鋁材
看以下連結第三幅照片,連配重,NASA把300多公斤東西放上去的。
http://www.pwtec.com/monolith_pictures2.htm
文章Nebulas » 2010-05-22, 19:11
社長 寫:派拉蒙赤道儀是市面上少數能負重比自重數倍的赤道儀,主要原因是每一台派拉蒙是花80機器小時,把100公斤T6061鋁材加工,去蕪存菁的只淨下必要的結構,造出一台30公斤不足的赤道儀,但David Levy等是用他來承200公斤望遠鏡的,那負/重比是1:6之鉅。
凭这点工艺特点就算是一个传奇了.
感觉特别像苏联的 AK-47 系列,坚固耐用。 开始我都说,是不是苏联东欧的特色。
Paramount相比 高桥赤道仪的‘艺伎’感,显得更像苏联红军。 :lol: 希望这个玩笑比喻不会引起啥争议的。
文章Nebulas » 2010-05-22, 19:12
社长所言,让我想起了一种做飞机的航空铝纤维材料。
文章Nebulas » 2010-05-22, 19:18
社長 寫:對,派拉蒙來自科羅拉多州,很慚愧的,個人第一次踏上4000米以上高峰,就是那裡的Pikes Peak,而非在中國土地上。
估计这设备很多买家买下来,还得培训一个星期。
今天我都还在想赤道仪的图纸设计和材料加工工艺呢。
文章社長 » 2010-05-23, 00:01
Nebulas 寫:
凭这点工艺特点就算是一个传奇了.
Bisque家族是波蘭裔美國人,他們大概對蘇聯、德國不會有很大好感..... :roll:
不過去年訂過好幾個不同型號的Astrophysics的赤道儀回來,之前也玩過好些高橋赤道儀,在巴黎望遠鏡展又見過那些EM500、EM400實物,坦白說,Paramount是很別樹一格的。
文章Nebulas » 2010-05-23, 14:48
看来追求望远镜的‘时尚’还是要跟着社长的体会和测试报告走。
昨天在北京和几个朋友测试了 P2 的赤道仪,在白天看太阳日珥的情况下,跟踪很到位,精度我想应该还不错。
文章社長 » 2010-05-23, 20:24
以白天操作來說,其實如何精確設定極軸更重要,我去年拍日全食便深有感想。
http://hk.myblog.yahoo.com/galaxyscient ... ex?&page=3
文章Nebulas » 2010-05-30, 23:56
社長 寫:以白天操作來說,其實如何精確設定極軸更重要,我去年拍日全食便深有感想。
有朋友介绍说,像 PRMT 这样的赤道仪,在天文台里面都是调一次,然后固定,长时间几个月甚至一年都不再去调的。
文章社長 » 2010-05-31, 00:17
若你像Daniel Bisque那樣熟手,就算從零開始調一次都是30分鐘而已,已可把極軸調至1角分內。
viewtopic.php?f=13&t=313
回到 儀器 - 台架及附件
正在瀏覽這個版面的使用者:沒有註冊會員 和 3 位訪客
