SkyScan and Autotracking Mount
TimothyYu » 2012-01-10, 11:17
I would like to ask does autotracking mount work with SkyScan??
TimothyYu
文章: 61
註冊時間: 2010-12-22, 07:45
來自: Hong Kong
Re: SkyScan and Autotracking Mount
文章社長 » 2012-01-10, 11:21
TimothyYu 寫:I would like to ask does autotracking mount work with SkyScan??
一個Synscan手控跟你整台鏡一樣貴,不要考慮了,而且你的不是赤道儀,在這模式下升級,實質意義不大的。
文章社長 » 2012-01-12, 16:37
老款的autotracking是不行的,劃分界限應該是08年後期出厰的就可以接了。
比較確定的判斷標準是要看簡易控制器的軟體版本是否為2.02以上 (但這個只能回厰查看)
文章TimothyYu » 2012-01-17, 23:36
This will be so bad that I expected the skyscan may not be so expensive and can't connect with my mount!!! :cry:
If I want to take photos on sky objects, I will need to buy a ED80 and at least a EQ3 pro.....
Now, I even can't take a photo with moon!!!
TimothyYu
文章: 61
來自: Hong Kong
文章社長 » 2012-01-17, 23:47
用 autotracking mount 拍月亮有什麼問題? 每張1/30秒曝光,拍一段半分鐘的,以你的小鏡解像度,我看不到場旋會造成任何問題,用單反拍更不成問題了。
文章TimothyYu » 2012-01-18, 00:16
One of the problem is I can't focuss the image with my 500d canon as I tried my telescope and other's telescopes still can't focuss :cry:
TimothyYu
文章: 61
來自: Hong Kong
文章社長 » 2012-01-18, 00:45
一些口徑很小的牛頓鏡,本身沒有足夠的後焦點讓單反合焦的,可以找個巴羅試試,否則用afocal方法。
另外若用數碼機加目鏡做afocal,效果也可以不錯的。
回到 儀器 - 台架及附件
正在瀏覽這個版面的使用者:沒有註冊會員 和 11 位訪客
