Unexpected performance of APM-LOMO 80/480
willis » 2011-04-19, 22:50
Today I did solar observations two times, Ha in the morning & white light in the afternoon. The proms were big in the morning. In the afternoon, I used the Equinox 120ED to do high power magnification. I plugged the Ethos 3.7mm into it and resulting a magnification of 900/3.7=243x. The view was quite good. One of sudden I want to see the limit of my APM-LOMO 80/480. I tried the 3.7mm on 80/480, the image is good. However when I added an 2.5x Powermate on it, the magnification was 480/3.7x2.5=324x, the image was bad. After that I tried the Ethos 10mm and 5x Powermate on 80/480, the magnification was 480/10x5=240x, the image is better than that of 120ED & 3.7mm despite of a dimmer image!
Re: Unexpected performance of APM-LOMO 80/480
文章社長 » 2011-04-19, 23:17
you mean unexpected or expected performance of your 2nd hand heavily used APM 80/480? :mrgreen:
文章willis » 2011-04-19, 23:25
社長 寫:you mean unexpected or expected performance of your 2nd hand heavily used APM 80/480? :mrgreen:
I mean how come a 80mm refractor beats a 120mm refractor.... :lol: In order to be scientific, I need to do a side by side test. But I don't have two Herschel Wedge! :?
文章社長 » 2011-04-20, 01:37
實事求是,你說的"較好"是很主觀的,須要更深入的描述。
正如在路邊天文,我發現要讓路人有認為影像"較好",用上較大視場的目鏡,較長的eye relief,可以容下整個月面及預留一些空間的倍率,影像稍亮便可以,跟口徑及解像度無關的。
文章sharkfin » 2011-04-20, 14:29
next time let us compare ethos 10 + 5x powermate and 2-4 nagler zoom using 80/480
and also compare ethos 3.7 and the 2-4 nagler zoom
sharkfin
文章: 43
註冊時間: 2010-05-05, 21:36
文章Robin » 2011-05-11, 22:37
社長 寫:實事求是,你說的"較好"是很主觀的,須要更深入的描述。
对,而且大众通常不会停留太久,那个initial impression就要通过大视场和高亮度的物体来刺激出来。像是那些要观测一阵子才能欣赏的暗天体大众就不懂得欣赏了。
Robin
文章: 181
註冊時間: 2010-11-24, 16:22
來自: Kluang, Malaysia
