DIY an artificial stars
willis » 2010-03-19, 23:53
I like to do experiment & DIY. Star testing a telescope needs a bright star. However, bright stars are not always present. Even u got a bright star, the transparency & seeing will affect the test result. So an artificial star is a resolution. BUT artificial stars are not cheap. 社長’s artificial star costs more than HK$2000! So I do it by myself. I borrowed the design from http://hubble-optics.com/artificial-stars.html
I asked my friend, a D&T teacher, to use laser to drill 5 holes on an acrylic plate. The sizes of the holes are 50um, 100um, 150um, 200um and 250um. Just put the acrylic plate in front of an LED torch and 5 artificial stars are formed! One can buy a powerful LED torch from Ap Liu street easily. Today, I tested my FS60C by this DIY artificial star at 178X. The diffraction rings are frozen and no more seeing problem. This provided a convenient, though reliable telescope testing. I have made 10 artificial stars. There are 9 spares. I will give them to the members of http://www.astrocafe.hk for free on the basis of first come first served. If u want it, please reply this thread. 社長 one is reserved for u. Can u help to distribute the artificial stars?
Re: DIY an artificial stars
文章社長 » 2010-03-20, 10:49
Thanks Willis for this great little tool, yes, please reserve one for me, and I can keep it in my office and help distribute it :P
香港以外的Astrocafers,因為這個東西很輕,用信封寄便成,空郵遠至加拿大也不超過三元,中國內地、台灣及東南才一元多,所以我免郵費寄給他們吧。
Astrocafers have a number of telescopes, it's time to setup simple yet powerful tools to test it. Its also good for optical alignment.
文章Lewis » 2010-03-20, 12:24
:o
我又要......
文章David » 2010-03-20, 12:45
So does this mean that I can, for example, collimate my C8, in the physics lab?
If so, please reserve one for me. :D
文章willis » 2010-03-20, 15:00
David 寫:So does this mean that I can, for example, collimate my C8, in the physics lab?
Yes! u can use it to collimate C8. Since the physics lab is not very long, the back focus of C8 may not support it. u may need to do it in the corridor.
Reserve list:
1. 社長
2. Lewis
3. David
文章xiaoer » 2010-03-21, 11:03
Reserve list:
1. 社長
2. Lewis
3. David
4. xiaoer
xiaoer
文章: 66
註冊時間: 2010-02-03, 10:00
文章社長 » 2010-03-21, 11:18
Willis, as I need to pass you the lighter counter weight for the EQ1, may be I can ask Ah Ying to collect these from you and mail to everybody who are interested.
文章David » 2010-03-21, 17:01
社長 寫:Willis, as I need to pass you the lighter counter weight for the EQ1, may be I can ask Ah Ying to collect these from you and mail to everybody who are interested.
Willis can pass mine to his colleague (you know who) because I will probably see her some time this week.
文章universe24 » 2010-03-21, 18:04
I am interested to have one also...very interesting stuff....
But I am live in Malaysia. Not sure 社长 can mail to me or not.... :?:
文章社長 » 2010-03-21, 21:08
universe24 寫:I am interested to have one also...very interesting stuff....
Chin兄,沒問題的,因為東西很輕,我放進信封寄給你就是了。
Reserve list:
1. 社長
2. Lewis
3. David
4. xiaoer
5. universe24
文章Henry Wu » 2010-03-21, 21:37
請幫我留一個  下次寄貨時一並寄到台灣  謝謝  Henry Wu (Taiwan)
文章willis » 2010-03-21, 22:10
Reserve list:
1. 社長
2. Lewis
3. David
4. xiaoer
5. universe24
6. Henry Wu
文章universe24 » 2010-03-22, 07:29
感谢社长。
还有感谢willis的用心。
另外,我想问下willis,那个laser切割,是否可以也切割出一条裂缝或者一条球面弧度裂缝,成为光谱仪的slit?
文章willis » 2010-03-22, 07:44
universe24 寫:感谢社长。
还有感谢willis的用心。
I think the laser cutter can make a striaght & curved slits. But how precise the curvature I need to check with my colleague. I am not the one who operate the laser cutter...
文章universe24 » 2010-03-22, 08:36
I see. Is that the laser can cut any material? Can cut glass?
Let say I got a rectangle first surface mirror, I would like to cut a slit on it. Is that possible?
Thank you very much.
文章willis » 2010-03-22, 08:51
It is a low power laser used in secondary school. It can only cut plastic.
文章universe24 » 2010-03-22, 10:29
I see I see...thanks again.
文章cwlam » 2010-03-22, 13:31
Hi Willis兄…可否預留一件給我呀?Thanks!
cwlam
文章: 31
註冊時間: 2010-02-01, 17:46
文章willis » 2010-03-22, 14:15
Reserve list:
1. 社長
2. Lewis
3. David
4. xiaoer
5. universe24
6. Henry Wu
7. cwlam
回到 儀器 - 自製器材專區
正在瀏覽這個版面的使用者:沒有註冊會員 和 5 位訪客
