最新 Lunt LS80T 太陽望遠鏡
Re: 最新 Lunt LS80T 太陽望遠鏡
David » 2010-08-25, 13:21
universe24 寫:From what I tried before, an exposure of 1/100 sec. still not fast enough to "freeze" particular part of the Sun.
As my current setup not allow me to use expsoure shorter than 1/100 sec., thus I don't how short is sufficient to beat the seeing.
I can use shorter than 1/100s at a focal length of 2250mm on prominence with LS152T. This is much better than LS100T which requires around 1/30s.
文章社長 » 2010-08-25, 13:53
David, shall we build an 8" reflector with uncoated optics, then modify it into a LS203T with your Ha module?
all at your cost, of course :lol:
文章universe24 » 2010-08-25, 20:09
Oh ya...I forgot that when I use 1/100 sec. is not enough, this is because I magnified the Sun quite big...about 4400mm.
I think by shorten the focal length to about 2000mm, that will be another story... :oops: :oops: :oops:
Regarding using uncoated reflector, I think there will have problem on scattering light from the bottom of the mirror.
As the glass is uncoated, so lights can pass through the 1st surface and reflect at 2nd surface, we might get double image.
Thus, I suggest at least coat a low reflectivity coating on the glass to constraint the light just from the 1st surface.
What do you all think?
文章David » 2010-08-25, 21:00
universe24 寫:I magnified the Sun quite big...about 4400mm.
Oh my god......
文章社長 » 2010-08-25, 23:02
universe24 寫:Regarding using uncoated reflector, I think there will have problem on scattering light from the bottom of the mirror.
I know what you mean, that really depends on which type of glass you use, e.g., dark & zero expansion one, I forget the source in Germany 8-)
anyway, low reflectivity coating may be easier. You know I have a LS75F unobstructed etalon, if I build a 203 reflector with lower reflectivity, I keep the light level within safe limit yet achieving very high resolution.
文章社長 » 2010-12-19, 02:38
David 寫:What else can I sell to get this.....
It will be interesting to see the performance of internal double stack.....with my LS152T!
X'mas gift!!
Shipment of LS80Ts, may pick up on Monday. One of that include a B1800 blocking filter. Shall we run a test against my LS75F? I will do that in my office first :mrgreen:
http://wwwapps.ups.com/WebTracking/proc ... 6746512310
文章willis » 2010-12-20, 00:12
So remember to bring ur unobstructed LS75F & APM 80/600 to ur office. Otherwise u cannot test it tomorrow. LS80T... I am waiting for u... :lol: :lol: :lol:
文章社長 » 2010-12-20, 00:27
I have everything in my office,
APM 80/600, 130/780, 100/800, 115/805, 203/1420, Paramount, LS75F, FS102, Mewlon 250, 2 metric tons of Sky Watcher, a handful of LS35T, LS60T, LS50F, The Imaging Source Cameras.... what else do you want? I just want cash :lol:
文章StevenTam » 2010-12-20, 18:08
社長 寫:I have everything in my office,
So we just need glorious sunshine. 8-)
Can't wait for it~
文章社長 » 2010-12-21, 20:16
今天到了,一台LS80T連包裝紙箱都重15Kg :shock:
為保障質量,我明天會為W及S用戶檢定一下才出貨,以APM-LOMO 80/600 + Unobstructed LS75F為測試基準  8-)
文章David » 2010-12-21, 23:18
社長 寫:今天到了,一台LS80T連包裝紙箱都重15Kg :shock:
Can I come to test?
文章StevenTam » 2010-12-22, 01:32
恰巧這月最新的Sky & Telescope是太陽特集,剛剛收到一看,立即想念起LS80T :roll:
希望明天也能趕及參與測試~ (努力諗書中...)
文章社長 » 2010-12-22, 08:36
今天天氣好,一起來測試好不好?我們把LS75及LS80搬上天台慢慢來...
David能把那Carl Zeiss 主鏡LS35T及DMK41帶過來嗎?你的Obsession 18UC及LS152T也會今天送返的。
回到 儀器 - 太陽觀測儀器
正在瀏覽這個版面的使用者:沒有註冊會員 和 12 位訪客
