今天到的 Lunt LS152T DSII (Double stack) 模組
社長 » 2014-09-08, 23:50
今天剛到的,為Astrocafe 的Dxxxx 兄所訂購,造價港幣2x,xxx,此雙濾可用於LS152T日珥鏡上,據聞功效奇高,包括:
- 加強傳說中的教學效益
- 成為Astrocafers 的聯誼話題
- 修復面對LS230T或LS160F時失去的自信心
viewtopic.php?f=19&t=316
viewtopic.php?f=14&t=3813
- 提升LS152T日珥鏡的日面細節對比度
Dxxxx 兄有一份XX情意結,任何新購的器材都堅持要自己開箱,但這次我出於好奇心,所以先下手為強,請見諒.... :mrgreen:
Re: 今天到的 Lunt LS152T DSII (Double stack) 模組
文章Raymond TSE » 2014-09-09, 14:08
Waiting for Dxxxx user review and comment.
Raymond TSE
文章: 132
註冊時間: 2012-03-13, 22:36
文章David » 2014-09-09, 18:04
Raymond TSE 寫:Waiting for Dxxxx user review and comment.
Honestly, I don't expect much from this because I have used LS100T with LS100F in double stack mode, and it didn't blow me away as I saw all the details in single stack mode anyway. However, many of my students really find it easier to see the details of the double stack image, especially for beginners. So this DSII is really for them.
However, I am sure that the Daystar Quark eyepiece is not for me. The August issue of Astronomy Now has a review and it says that it takes 15 minutes for the etalon to reach the correct temperature. Also, my students and I enjoy full disc view much more than high magnification view. This cannot be delivered by the Quark eyepiece unless one uses a small refractor with very short focal length.
I will have 5 combinations to try and compare:
1. LS100F single
2. LS100T single
3. LS100T+LS100F double stack
4. LS152T single
5. LS152T+DSII double stack
DSII is really expensive and honestly it is probably not worthwhile at all if I don't have so many students to share it with.
文章kelvincheboy » 2014-09-10, 14:24
- 加強傳說中的教學效益
很有興趣是什麼教學效益? 是指初學者更容易目視太陽細緻的結構?
kelvincheboy
文章: 127
註冊時間: 2013-08-31, 00:41
文章kelvincheboy » 2014-09-10, 14:27
60T在目視上還欠缺一些 , 我是沒問題但學生在太陽底下黑子是容易看見 , 但日面上的結構學生反而''眼力不夠''而錯失一些細緻部分 , 只能靠拍攝呈現 , 希望100T目視上會有出色的效果。
kelvincheboy
文章: 127
文章社長 » 2014-09-10, 14:38
我的是半開玩笑,不用太認真。
但David的意見可供參考 "many of my students really find it easier to see the details of the double stack image, especially for beginners. So this DSII is really for them."
文章社長 » 2014-09-10, 14:39
David 寫:I will have 5 combinations to try and compare:
1. LS100F single
2. LS100T single
4. LS152T single
more innovative :lol:
LS100F + LS152T + DSII triplet stack
LS100F + LS152T double stack
文章StevenTam » 2014-09-10, 15:54
哇哇哇~ 至少我相信在攝影效果上會強很多 8-)
文章社長 » 2014-09-10, 16:04
double stack is not for imaging, too dim.
just set the Gamma lower and you will got similar effect as double stack system.
so for the same money, but bigger, single stack system.
文章社長 » 2014-09-10, 16:43
今天xxxxd兄來提貨,也帶了自己的LS152T來,星河科研社提供免費安裝服務。
LS152T加上DSII模組後明顯重了一截,重心也移後了,星河科研社提供AZ EQ6或Paramount MX赤道儀3%優惠升級服務,兩款赤道儀均有現貨可供選購。
xxxxd兄看來提得很吃力,但我事忙無暇陪他步行回火車站,故略盡綿力,幫他按一下升降機鍵便算了.... :oops:
文章David » 2014-09-15, 17:56
Some students and I had a quick look during lunch time at low magnification (full disk). Here are some quick impressions:
- With LS152T single mode, the solar disc is very bright, washing out some details although they are certainly observable.
- After adding the DSII, as expected, the contrast is much better. But I won't say that the image blows me away. The disc is still very bright. As I like to see bright image, so that's good. There is a big prominence and it was as lovely in double as in single.
- When compared with my memory of LS100T+LS100F double mode, the double stacked 100mm image is already not very bright for my taste. But the dark filaments seem to be more darker and more obvious in 100mm, perhaps due to the dimmer image.
- So it seems that LS152T+DSII is best used with binoviewer so that the image can be dimmed a bit more. Perhaps the brightness I get then will be just what I like. I'll also try higher magnification later.
文章社長 » 2014-09-15, 20:42
我之前一直推薦愛好者,同樣的預算下,買大一級的單濾而非細一級的雙濾,上次測試完LS230T後,我們都同意,看Ha太陽,152仍未到大氣許可的盡頭 :mrgreen:
viewtopic.php?f=14&t=3813#p24511
文章Raymond TSE » 2014-09-15, 22:25
I am still figuring out how to get 235mm aperture Ha single stack :roll:
Raymond
Raymond TSE
文章: 132
文章社長 » 2014-09-16, 08:36
當年廖生跟我說,生命太短,要玩的器材大多,沒時間DIY了,Raymond考慮現成的吧.... :mrgreen:
當然我同意Lunt應在LS152T、LS230T之間加一個型號,例如LS180T或LS200T之類的。
文章David » 2014-09-19, 06:53
We were all spoiled by the full disk view using binoviewer plus the double stacked LS152T :oops:
文章社長 » 2014-09-19, 17:05
懇請小心保管我的Baader Mark V 雙目 :twisted:
想試試用兩個Ethos看嗎? 那才叫 "Immersive"。
回到 儀器 - 太陽觀測儀器
正在瀏覽這個版面的使用者:沒有註冊會員 和 25 位訪客
