新產品 - Lunt LS230T 日珥鏡
社長 » 2013-03-06, 10:02
新產品 - Lunt LS230T
僅售 HK$182,600 8-)
星河科研社為亞洲地區代理
We are excited to announce our next batch of LS230THa/PT/B3400! We are only making 7 units for this batch. Please make sure to get your orders in ASAP. Our last batch of LS230THa scopes were sold out within the week. Delivery is one per month based on orders taken.
The LS230THa/PT/B3400 is the largest aperture solar telescope currently available. The 100% unobstructed system will perform to the highest level at both low and high magnifications. With an image size of almost 16mm at the eyepiece, the view thru this instrument is truly breathtaking. Utilizing advanced hi-contrast coatings and the new Doppler True Pressure Tuning system the user will be able to experience an un-paralleled level of visual and imaging performance. We are now including the Pressure Tuner Controller (PC1) with each LS230THa. This will allow users set and stay at a center wavelength set point.
LS230THa/PT Specifications:
Optical Aperture: 230mm (Unobstructed)
Etalon: Internal <0.65 Angstrom
Tuning: Internal Pressure Tune with PC1
Focal Length: 1610mm
F Ratio: 7
Focuser: 2″ Starlight Instruments Feather Touch
Mounting: Rings with 12″ Losmandy style plate and carrying handle
Weight: 70 lbs (estimated) Shipping weight: 90lbs
B3400 straight thru installed in the focuser standard
Included Accessories: (see “accessories”)
Eyepiece: Lunt Zoom Eyepiece
Mounting: 12″ Losmandy Style Dovetail Plate
Lunt Solar Systems
Re: 新產品 - Lunt LS230T 日珥鏡
文章社長 » 2013-06-06, 18:31
首台將於今年稍後抵港,屆時請David驗收,有興趣者請及早加入團購..... 8-)
文章David » 2013-06-07, 19:09
社長 寫:首台將於今年稍後抵港,屆時請David驗收,有興趣者請及早加入團購..... 8-)
我盡可能抽空幫手 8-)
文章社長 » 2013-11-28, 14:01
David 寫:
我盡可能抽空幫手 8-)
Lunt 確認12月出貨,貨運資料:187 x 66 x 74cm,總重 41kg。
剛收到客戶通知,要求我們參與驗收,屆時用Paramount 或 Skywatcher EQ8架起來拍些照片吧。
為了答謝David你的幫忙,我會確保下月西藏星空派對時,你每天會不少於8小時的充足氧氣供應,晚間睡覺時室温比外面氣温高15度以上 :mrgreen:
文章Raymond TSE » 2013-11-28, 17:31
未能參加"團購",但可帶BV+EPs與David參加"團驗"。 :mrgreen:
Raymond TSE
文章: 132
註冊時間: 2012-03-13, 22:36
文章社長 » 2013-11-28, 18:07
作為 150 > 230 的潛在升(星)級客戶,歡迎歡迎 :mrgreen:
不過到時容許測試的日子不多,因為要馬上交給客戶,到時真的要你遷就一下時間了。
文章Raymond TSE » 2013-11-28, 22:46
Want to know whether there will be surprises from the stepping up :?:
Raymond TSE
文章: 132
文章社長 » 2013-11-29, 08:18
看過LS160F後你會知道跟LS152T不在同一層次上:
viewtopic.php?f=19&t=316#p2790
但肯定LS230T首先給你Big surprise in price step up :mrgreen:
文章David » 2014-01-15, 18:26
將帶細小的LS152團驗
文章社長 » 2014-01-16, 17:54
Lunt LS230T 全球最大日珥鏡太陽派對,今日完滿結束 8-)
viewtopic.php?f=14&t=3813&p=24510#p24510
感謝David帶同尋星鏡級別LS100T到場助慶,以及入門級別LS152T作基準測試。
作為兩位LS152T用家,David及Raymond Tse對LS230T及Skywatcher EQ8表現充份肯定 :mrgreen:
文章社長 » 2014-06-15, 23:17
要毒一下未有LS230T的Astrocafers 8-)
圖片來源 :
https://www.facebook.com/photo.php?fbid ... =1&theater
文章vr2il » 2014-06-16, 07:18
呢張真係劇毒 :shock:
如果併一張全日面真係不得了 :mrgreen:
vr2il
文章: 172
註冊時間: 2012-07-03, 21:14
文章Raymond TSE » 2014-06-16, 08:51
The photo is not taken by LS230Ha/T but a modified PST of 1A bandwidth only through a 230mm F11.2 (Ha wavelength optimised) DIY scope.
This demonstrates the very exceptional & surprisingly good quality of PST under high magnification.
According to this imager from South France with very good seeing , many photos taken by modified PST even surpass the new released
Quark 0.5A Ha eye-piece using the same setup.
This makes a hard choice between the mature product slightly cheaper PST (1A) and the good spec newly developed Quark (below 0.5A) Ha EP.
Raymond
Raymond TSE
文章: 132
文章社長 » 2014-06-16, 11:03
Raymond 你應該也留意一下新出的Lunt LS50T的後模組,也是PT的。
LS35T在外國稱為PST Killer,那Lunt的PT後模組.... ;)
邏輯上,Andy Lunt及其老爸David Lunt十多年前創立Coronado,後來賣給Meade,後來David Lunt過身了,Andy Lunt 在2008引入APM的德國技術(部份東西是Philipp Keller設計了,他也是世界各地一些米級科研鏡的設計者,以及ASA的靈魂人物),以及NEAF主席做股東,這幾年你也看到Lunt在技術上的發展了。
文章Raymond TSE » 2014-06-16, 13:04
Dear Savio,
Any link or photo of this
"Lunt LS50T的後模組" ?
To take advantage of the maximum aperture benefit of the front objective, usual PST modification at the rear would involve a F10 converging light beam system.
Not sure whether LS50T use a parallel beam or converging beam.
Raymond Tse
Raymond TSE
文章: 132
文章社長 » 2014-06-16, 15:06
按 Andy Lunt的說法,就算是鏡前濾鏡,接受的入射光線也不是平衡光線,因為太陽本身也是有面積的,所以重點是Sweet spot有多大。
除了ERF外,另一構思方向是用無鍍膜的反射鏡,但涉及大多我未試過的細節,下刪5000字..... :roll:
回到 儀器 - 太陽觀測儀器
正在瀏覽這個版面的使用者:沒有註冊會員 和 31 位訪客
