M45 @ Ching Jing
M45 @ Ching Jing
benben88 » 2011-01-06, 23:45
Details :
FSQ106ED + reducer , ST2000XM (-10C) L 4 min X 23 , RGB 4min X 2 (2x2 bin) , GPD, 9X 50 finder PHD auto guide.
M 45 LRGB.jpg (322.78 KiB) 被瀏覽 5980 次
Re: M45 @ Ching Jing
文章社長 » 2011-01-07, 23:25
Ben 請教一下,這張照片做了什麼後期處理? 我自己拍的表現不太好... :oops:
文章willis » 2011-01-08, 07:48
benben88 寫:Details :
I saw ur DSOs u posted carefully. I found that ur post-processing is very good, especially the control of color tone. I would say u got ur own style. This makes u standand out from others. I don't have my own style & I just produce what my equipment can produce.... :oops: Would u mind to share with us in general how to do it?
文章Nebulas » 2011-01-09, 13:00
社長 寫:Ben 請教一下,這張照片做了什麼後期處理? 我自己拍的表現不太好... :oops:
这种“看似过曝”的片子,体现了恒星的光芒感!
头一次看到,相当不俗。
文章benben88 » 2011-01-09, 23:19
willis 寫:
Hi Willis
Actuallu my image processing skill is still very poor. Sometimes I found my color tone cannot be managed easily , I think some of them are too pale . I couldn't fix it using the saturation of PS (even I use a layer mask to select the nebula) . I use Kernal filter the stretch the photo of the L channel first and this can not only maintain the bright part but also reveal the very faint regions. However, this cause the problem of the colour after merging with RGB.....
Will try other processing method later after doing some research . Anyone here can share the technique of processing?
Ben
