2010-12-29 LVI 開光
2010-12-29 LVI 開光
Lewis » 2010-12-29, 07:54
Date: 2010-12-29
Time: 01:31
Equipment: Nikon D300s, Nikon 80-200mm f2.8, HEQ5P, LVI (1), Shutter.
Object: M42
ISO: 800
f-Number:2.8
Shutter speed: 24min 27sec
Original size: 4288x2848
Sources: 8 RAWs stacked.
DeepSkyStacker
Photoshop (Level, Curve)
開光啦,開光啦。
LVI: easy to setup, even exposure about 10mins.
Limitation:
LENS: Cheap Cheap Camera LENS ($7xxx) <- really cheap.
Camera: Unmodified D300s, quiet good that can see whole picture of "馬頭" and M42 (Very Happy).
最後由 Lewis 於 2010-12-30, 18:44 編輯,總共編輯了 1 次。
Re: 2010-12-29 LVI 開光
文章Lewis » 2010-12-29, 08:04
Date: 2010-12-29
Time: 01:31
Equipment: Nikon D300s, Nikon 80-200mm f2.8, HEQ5P, Shutter.
Object: Rose Nebula
ISO: 800
f-Number:2.8
Shutter speed: 17min 25sec
Sources: 5 RAWs stacked.
DeepSkyStacker
文章willis » 2010-12-29, 16:16
Last night I forgot to bring the tripod, but the mount head! Luckily u share the mount with me, otherwise I would waste the beautiful night!!! Anyway, the auto guiding was excellent last night. We shoot more than 3 hours & all of the frames showed no tracking problem! LVI guided excellently last night! After reflection, I should not use a 60mm small scope last night , because it was a waste. I should use my 80mm or larger scope instead...
Back to ur photos, apart from the spherical aberration of camera lens at the corners, the tracking was good. It is a good start, the next challenge is move up the focal length and see if u can guide up to 1000mm!!!
文章Lewis » 2010-12-29, 17:09
willis 寫:Last night I forgot to bring the tripod, but the mount head! Luckily u share the mount with me, otherwise I would waste the beautiful night!!! Anyway, the auto guiding was excellent last night. We shoot more than 3 hours & all of the frames showed no tracking problem! LVI guided excellently last night! After reflection, I should not use a 60mm small scope last night , because it was a waste. I should use my 80mm or larger scope instead...
I still thinking why you didn't use your Equinox. Maybe next time, the sky will tell us.
Tonight, I will going to process your CAMERA's Raw and sharing the experience with you.
Next time, saving up much more money to buy a modified camera or my old one (300D).
Next next time, set up the Newtonian .......... :~~~~. (Last night,we wasted so much time to calibrate .....)
文章社長 » 2010-12-29, 19:35
很高興昨天的Star Party看到Lewis自動導星開光成功,有能力把照片質量帶上另一台階了 :P
導星就是這麼簡單,純粹一個回輸訊號而已。
談及攝影鏡頭,我個人看,日後若真的要換,數千元的短焦折射鏡也會比同焦距的昂貴鏡頭星點要銳利。
目前你和Willis好好用我的130/650攝星牛反拍些照片吧,稍後出一個測試報告就是了 8-)
文章Lewis » 2010-12-29, 22:14
社長 寫:目前你和Willis好好用我的130/650攝星牛反拍些照片吧,稍後出一個測試報告就是了 8-)
Of course, when the sky tell us, we will going to take the photos.
文章funoooo » 2010-12-30, 15:58
Lewis,
Good starting and Welcome to LVI II team. :mrgreen:
文章社長 » 2010-12-30, 17:51
no, he listen to my advice - use LVI I
so Lewis and me is LVI I team, you, Willis, David, Xiaoer.... are all LVI II team 8-)
文章willis » 2010-12-30, 22:15
社長 寫:no, he listen to my advice - use LVI I
For simplicity, LVI team! :lol:
正在瀏覽這個版面的使用者:沒有註冊會員 和 27 位訪客
