M8
M8
benben88 » 2010-08-05, 22:34
Hi all,
Photo for sharing, took on 3 Aug 2010 at Yuen Long.
10 inch F4,7 newtonian + Paracorr, V4 filter, ST2000XM.
L 120s X 28, R 120s X 2 ,G 120s X 2 , B 120 X 3 , RGB 2x2 binning.
Guide by Vixen 80s + 2x with PHD.
Forgot to take flat ... :shock:
Ben
M8
Re: M8
文章社長 » 2010-08-05, 22:49
Hello Ben, 您的孩子什麼時候光臨?
我在這裡的所有照片都沒有Dark沒有Flat的..... :lol:
Re: M8
文章willis » 2010-08-06, 11:13
With post processing, flat field and dark frame etc are just like a lady wearing make-up. Otherwise, it is a lady wears no make-up. Anyway, it seems that there is CA. Is it comes from the corrector?
Re: M8
文章社長 » 2010-08-06, 12:28
從各星有不同方向的色散看,那些應不是光學系統色差,或許做一下RGB Align會好些,我猜可能包括以下原因:
1. 大氣色散,因為M8的仰角不高,去年拍木星也會有這現象,而混入L通道後是拆不開的
2. 可能導星在視場外,或極軸未完全對準,有少許場旋,所以拍RGB的期間星點已有偏移
這只是我猜想,Ben會清楚一點,但肯定是後期處理可以大幅度解決的,這幅照片也展示了1200mm焦距應有的解像度。
Re: M8
文章benben88 » 2010-08-06, 18:47
willis 寫:With post processing, flat field and dark frame etc are just like a lady wearing make-up. Otherwise, it is a lady wears no make-up. Anyway, it seems that there is CA. Is it comes from the corrector?
Flat field is a must in CCD photography , it can eliminate the shadows of dust on the image and correct the vignetting of the setup .
There should be no CA for the Televue comacorr (Badder coma corrector has tiny CA and also spherical aberration and I am not using it in CCD photography). The alignment of the frames is not that great but I don't know why everytime I use PHD in guiding , the star in each frame is round but the field shifts a bit between frames . So after 1 hour L frame captured, the field shifted quite a lot..... There is no such problem if I use the self- guider or ST4 in Maxim DL.
Re: M8
文章社長 » 2010-08-06, 22:09
Ben, you think anything related to field rotation? is your guide star inside the field?
I have no experience in PHD guide or ST4, I only pick up deep sky imaging recently because standalone and low power consumption auto-guider available, in additions to modified full frame DSLR with liveview.
Re: M8
文章benben88 » 2010-08-07, 21:08
社長 寫:Ben, you think anything related to field rotation? is your guide star inside the field?
No, the guide star is 2-3 degree away . Let 's see if you can hold a LVI workshop and demonstrate to me later :D
Re: M8
文章willis » 2010-08-07, 22:02
benben88 寫:
Hi Ben! I made an over-do statement. It should be post processing is just like a lady wearing make-up. However for the flat field, if the telescope & the flattener are optically excellent, there is no need to apply flat field in the processing. As 社長 mentioned "我在這裡的所有照片都沒有Dark沒有Flat的....." No kidding and I tried APM APOs with proper flattener, there is no need to apply flat field. There is no obvious vignetting in full frame DSLR. If u are talking about APS size DSLR, flat field becomes a waste of time. :lol: I know some well-known astrographs, they really need flat field. :lol: The word "Astrograph" becomes a comercial name. I suppose the field of an Astrograph should be reasonably flat. But the reality is not. I reckon the term astrograph should be defined by performance, not just a name. So flat field or not, depends on what telescope u are using.
Clear Skies!
Willis
Re: M8
文章社長 » 2010-08-07, 23:53
Willis,平場除了處理漸暈外,也有很多功能的,例如Ben說到的麈埃問題,以及一些不平均的感光問題等。
我在台灣拍的照片全部都沒有後期處理平場暗場,一來是我還沒準備好座枱電腦,目前的手提電腦根本應付不了很複雜的處理,這兩星期收拾好辦公室後便會進台i7 core的模擬8核心電腦,另一個原因是我不介意把沒平場暗場的照片分享,讓大家看到我所用的APM-TMB折射鏡及Modified 5D Mark II的原始成像水平如何,但這一切不代表平場不重要,我稍後還是會一一處理的,所以你看到我在武嶺每一天都有拍暗場,也每一個光學組合都拍了平場,稍後便會重新處理照片,而M31那張也會補回一些Ha, OIII等通道。
Re: M8
文章社長 » 2010-08-07, 23:55
benben88 寫:
I don't think 2-3 degree will have any effect on field rotation.....
yes, you can come and join us for next deep sky imaging workshop, or you can join Willis', I just talked to David and Willis that I will focus on imaging Jupiter these 2 months, due to some mistakes, what I didn't last year is not good to my standard, will do much better this year.
viewtopic.php?f=16&t=43
