Horsehead @ Cing Jing (reprocess)
benben88 » 2011-05-02, 20:54
Details :
FSQ106ED + reducer, ST2000XM (-10C) L 4min X 39 , RGB 4 min x 4 (2x2 bin) , GPD + 9X50 finder PHD guiding.
This time I didn't use MaxIm DL to do the colour stack , all the LRGB combined in PS and processed by CS 4.
Horsehead LRGB LIC s t.jpg (526.69 KiB) 被瀏覽 11403 次
Re: Horsehead @ Cing Jing (reprocess)
文章willis » 2011-05-02, 21:33
The color is very nice & the s/n is high! As u mentioned u used different processing, can u also post the previous one so that we can compare the differences.
文章Lewis » 2011-05-02, 22:09
:shock:
But, the compression of JPG is too high that we can see some square near Alnitak.
文章社長 » 2011-05-02, 22:12
Ben 好像以前問過一次,不過再請教一下,以你的設定來說,RGB下是否不容易用guide chip找到導星?
我用派拉蒙好一點,1420mm若是拍三五分鐘的,盲跟便算了,所以若有guide chip的,曝光30秒修正一次無可以  :mrgreen:
另外圖片是1200x915的,是裁切了或是縮了圖? :roll:
文章benben88 » 2011-05-02, 22:18
Lewis 寫::shock:
It has nothing to do with the compression , it has something to do with CCD and I also notice this in other people's CCD photos...... I do not know the reason and it exits in the fits files of my CCD .
Could anyone explain ?
Ben
文章benben88 » 2011-05-02, 22:27
社長 寫:Ben 好像以前問過一次,不過再請教一下,以你的設定來說,RGB下是否不容易用guide chip找到導星?
I did not use the internal guide chip as I was using my old GPD which has no relay to support Sbig guiding caple ( I used shoestring relay box+ external guider + Phd) . I think it is not a problem in a dark site to find a guide star as I can always find a guide star for 500mm at Yuen Long (5 s exposure) . But for Ha , it is nearly hopeless to get a guide star .... :|
Yes I cropped a bit as I took the frames in 2 nights ( no auto-goto , only " human meat" go-to the same area) so quite a bit non-overlapping area discarded....
文章benben88 » 2011-05-02, 22:29
willis 寫:The color is very nice & the s/n is high! As u mentioned u used different processing, can u also post the previous one so that we can compare the differences.
viewtopic.php?f=17&t=679&p=6701&hilit=Horsehead#p6701
文章willis » 2011-05-03, 23:06
benben88 寫:
The previous version is a bit pale. But in comparing the previous version & present version, the present version seems over saturated a bit. Would u mind if I process ur previous photo & post it here?
文章benben88 » 2011-05-04, 11:37
willis 寫:
benben88 寫:
No problem.
文章willis » 2011-05-04, 21:00
Thanks Ben! I guess the ur previous version got better details so I processed ur previous version with PS. I just boosted up the color.
文章benben88 » 2011-05-04, 21:49
Good :) Augus adviced to colour stack RGB in MaxIM DL and combine the L with the RGB in PS. Will try later .
文章Nebulas » 2011-05-12, 20:07
今天回顾下此帖,很棒!好的片子都是相似的,不好的片子各有各的名堂!距离市区八十公里已探明一路线,海拨900左右,有吃有住,下次若来时能长住半月便好,九月秋季武汉北郊的星空很灿烂,此处风景不错,两人在此度假吃喝住半月消费应不会过一个iPhone 4!
文章benben88 » 2011-05-12, 21:23
Thanks for the info, hope I have the chance to go there soon :)
文章Nebulas » 2011-05-13, 11:32
benben88 寫:Thanks for the info, hope I have the chance to go there soon :)
Today, a member have been to the place, and I ask for the info details. If it's fine, I could give you some plan later.
I think the reflector should be more worthy although it's not easy to carry for you.
Nowadays, many friends leave their equatorial and other equipments in my house for convienent observation. :D
