金星凌日 2012 -HK Yuen Long
benben88 » 2012-06-06, 14:59
Photo for sharing :
Wide field - FSQ 106ED(baader filter ) + 2X telephotolen Canon 500D
Close up : C9.25 (stopped to 8 inch) baader filter + DMK 21
IMG_2040 s.jpg (119.25 KiB) 被瀏覽 6620 次
PF C 9.jpg (33.71 KiB) 被瀏覽 6620 次
Re: 金星凌日 2012 -HK Yuen Long
文章社長 » 2012-06-06, 17:50
我錯過了最後階段,甚至12:51開始下幾滴雨,之後吃飯回來便放晴 :evil:
文章David » 2012-06-06, 17:57
The high magnifications shot was lovely. Did you manage to capture the atmosphere?
文章benben88 » 2012-06-06, 18:57
David 寫:The high magnifications shot was lovely. Did you manage to capture the atmosphere?
:cry:This was the last shot! I made a serious mistake when Venus came out , I wanted to move the planet to the center but I forgot the mount had been restarted and the slew speed was set to 500X , I lost the planet eventually and I concentrate on visual. I am quite sure I saw the atmosphere when 1/4 Venus came out from the sun for a while with a 130 APO at 156 x n 280x.
文章David » 2012-06-06, 19:09
Oh dear! I also find that accidents can happen no matter how careful one prepares. My Canon lens immediately had fog all over it when I took it out to shoot this morning...after spending one night in an air conditioned room. This explains why I got no second contact pic!
I saw the atmosphere too with the 12 inch dobs very shortly after third contact with 9mm plossl (about 170x).
文章willis » 2012-06-06, 19:57
Very nice shots especially the high power shot! I was using M8, 2000mm, I found that the seeing didn't support that! :(
