太陽派對 - 補課篇 (20110314)
David » 2011-03-14, 17:25
前數天的太陽派對因天氣問題未能盡興,今天其中一位同好有空,於是進行了一次「補課」,出動了不少器材,包括:
LS152T+12mm Nagler和6mm Ethos
LS100F+APM 80/480折射鏡
Denk II Binoviewer
Lunt CaK module
APM Herschel Wedge + Baader Solar Continuum Filter
今天的太陽非常合作,提供了不少日珥、黑子和絲狀物,用LS152T+Binoviewer觀察,效果震撼無比。我們也用CaK module觀察,用APM80/480折射鏡配合Lunt 7-21mm Zoom目鏡時,低倍觀察時影像很光亮。其實CaK濾鏡不是只能攝影用,目視也很有趣的。
Re: 太陽派對 - 補課篇 (20110314)
文章David » 2011-03-14, 17:26
Monster filaments processed by Avistack 2 and Registax 5.
With registax 5
With Avistack 2
文章David » 2011-03-14, 17:30
Full disk pics
文章David » 2011-03-14, 23:18
Active regions, processed with Avistack 2 and Registax 5 respectively.
With Registax5
With Avistack2
文章Andy » 2011-03-14, 23:32
Wow ! A 3D pic !! 8-)
Andy
文章: 27
註冊時間: 2010-02-08, 23:02
文章pleiades » 2011-03-16, 00:43
多謝 David Sir 幫我補課, 展示各式各樣太陽觀測器材和示範 imaging, capturing and processing images.
真是獲益良多 !!
用LS152T+Binoviewer觀察,看到日珥、黑子和絲狀物等等, 效果震撼,
還比較了幾天前David拍的太陽照片, 太陽面貌變化多端
另外用 Calcium-K Module 觀察別有一番風味 : )
其中一張太陽照片
用 David 在 AstroCafe 教的方法 Photoshop + CaptureOne 第一次出相
嘗試日珥合成中 ...
看來除了要再鑽研 PS 和 CaptureOne
還要添置太陽觀測儀器 : p
pleiades
文章: 47
註冊時間: 2010-02-04, 20:54
文章David » 2011-03-16, 11:10
pleiades 寫:還要添置太陽觀測儀器
I just worry that nothing is good enough for you after using LS152T if you are into H-alpha observation! :lol:
A Herschel wedge may be a good choice for your 5 incher.
文章社長 » 2011-03-16, 11:34
David 寫:
his lens is of 98% strehl, so is perfect for white light observing / imaging with Herschel wedge and Baader green continuum filter 8-)
oh, sorry Tony, I hope the strehl of your lens is not privacy? :mrgreen:
文章pleiades » 2011-03-18, 16:32
haha, the strehl is nothing private at all : )
i am very happy with this high strehl ratio
really look forward when i set it up and have a first look through the scope !
by the way ... i am considering getting a herschel wedge and some filters ...
i will be working for 5 weeks of night shifts ...
no time for night sky oberservation until the 6th week : (
pleiades
文章: 47
文章社長 » 2011-03-18, 17:56
no time for night sky observation? 那看太陽吧 :lol:
我有Herschel wedge, 1.25" ND3, Polarizer, Baader green continuum等濾鏡現貨的,在香港買好日後便省郵費。
1981年 Roland Christen的自製5" oiled triplet APO (即後來的Astrophysic系列折射鏡)贏了一個望遠鏡製作大奬,他在Sky & Telescope上發表文章說,一個造工良好的折射鏡是無價之寶,當我90年代走進南京大學天文系教學樓頂的天文台,用那台半世紀歷史的Carl Zeiss 5寸折射鏡看火星時,又或者08年走進Yerkes用那台一個世紀老的全球最大折射鏡推上500x看M5球狀星團,我對此有深深體會。兩台鏡所有機械部件都灰塵滿佈的,但鏡頭郤維持極高水平表現。
Roland Christen當年說沒有一台8寸施密特卡色會比他的5寸APO好,到今天C8、M8都進步很多了,但LZOS的工藝也比當年的Astrophysics好,在光學設計上空氣頭也比油頭APO有更大優勢,所以在你的hometown,可能試試跟其他鏡比一下光學表現,當然一定要用上那Mono 4及Mono 6啊,唯一是我看倍率仍不夠高,在視寧度許可及鏡頭得到充份冷郤後,推近300倍會更好。
文章David » 2011-03-18, 21:12
pleiades 寫:by the way ... i am considering getting a herschel wedge and some filters ...
When viewing with herschel wedge with my APM80/480, we thought that a Ethos 3.7mm may be great - a 130x full disk white light sun! 8-)
文章社長 » 2011-03-18, 21:36
I tried a few days before, Ethos 8 on 203APO, it can handle the whole half moon at 178x on one side of the field, so definitely ok for full moon 8-)
文章David » 2011-03-24, 10:17
Pics processed with avistack 2 added above.
文章StevenTam » 2011-03-24, 17:48
AVIStack 2 明顯勝過Registax 5, 色彩還原度更好,訊噪控制也比較好,偏油畫的感覺看上去更舒適,另外我感覺AVIStack的AI很優秀,全自動整理也能輕易獲得不錯的效果,唯一可惜的是不知為何最新版本未能支援DMK拍攝的Y800,需要找另一個軟件先進行轉換。
文章社長 » 2011-03-24, 18:25
StevenTam 寫:AVIStack 2 明顯勝過Registax 5, 色彩還原度更好,訊噪控制也比較好,偏油畫的感覺看上去更舒適,另外我感覺AVIStack的AI很優秀,全自動整理也能輕易獲得不錯的效果,唯一可惜的是不知為何最新版本未能支援DMK拍攝的Y800,需要找另一個軟件先進行轉換。
我的月面也是用Avistack去疊Y800的,沒問題啊。
文章David » 2011-03-24, 18:50
社長 寫:我的月面也是用Avistack去疊Y800的,沒問題啊。
I also use Y800 to shoot. Did you download avistack 1 or 2? Some computers that I use do not support avistack 1. I encounter no problem with avistack 2.
I guess the main advantage of avistack is that its alignment boxes cover the whole picture. Hence it is best when the region of interest is very large, like lunar and solar pictures. Therefore, the whole pictures will be well aligned - The whole picture looks sharper.
For pictures with small region of interest (e.g. planets, solar prominence), I heard that Registax is still the best.
文章David » 2011-03-24, 18:55
StevenTam 寫:色彩還原度更好,訊噪控制也比較好,偏油畫的感覺看上去更舒適
I am not sure if these are related to avistack because the registax and avistack pics are processed differently in photoshop.
文章StevenTam » 2011-03-27, 11:39
在Y800拍攝的影片,我之前利用1.81整理的話並沒問題,能阿順利開啟和整理,但當升級至2.0之後就顯示為Codec not support...我再裝回1.81再嘗試一次, 同樣顯示為Codec not support...
我上網搜查過一些資料,發現有同好擁有同樣的問題,部份說是WINDOW上IDL的問題,部份則說Y800也有兩種制式,暫時也未找到完整的解答,現唯有再透過另一軟件先轉換AVI的格式 (Y800同為AVI),再放入AVISTACK使用。
文章pleiades » 2011-03-29, 03:20
看不到廿八日的太陽 ... 晚上天氣又多雲看不到星星 ...
悶悶不樂 ...
又要開始"執包袱" ...
清理電腦時找回張上次補課後試過做的日珥合成 ...
很難將日珥完美地從太陽本體分離出來 ...
結果如下 ...
pleiades
文章: 47
文章David » 2011-03-29, 10:22
pleiades 寫:清理電腦時找回張上次補課後試過做的日珥合成 ...
很難將日珥完美地從太陽本體分離出來
I think it looks okay. You can check out the following website which is a collection of many solar pictures taken by amateurs all over the world. I use it to compare my standard with other imagers and get inspirations on how to process the pictures.
http://www.seemysunspot.com/1210.html
The sun looked really nice yesterday. I did have a look during lunchtime. 8-)
