12-3-2011 First light of Lunt B1200 CaK module
willis » 2011-03-12, 18:01
This is the first light of my CaK module. I took it at home. Due to the orientation, the field of view is blocked by the frame of the window! :? :? :? It certainly degraded the contrast & resolution a bit. Anyway, it is just a trial run.
APM/LOMO 80/480
DMK41
APM80-48_CaK0003 11-03-12 12-59-23_4.jpg (110.34 KiB) 被瀏覽 6511 次
Re: 12-3-2011 First light of Lunt B1200 CaK module
文章David » 2011-03-13, 01:12
I see that you are quickly addicted to CaK! Any tracking used?
文章willis » 2011-03-13, 09:01
David 寫:I see that you are quickly addicted to CaK! Any tracking used?
No. I just used a Porta mount.
文章StevenTam » 2011-03-18, 22:36
Whenever which time to see this picture, still a good shot!
文章社長 » 2011-03-18, 23:32
I am going to setup my own astrocafe-standard Cak telescope also - APM 80/480 + Cak 1200 8-)
I am going to setup my own astrocafe-standard Cak telescope also - APM 80/480 + Lunt Cak 1200 8-)
