Active Region AR1654
David » 2013-01-11, 21:19
The active region AR1654 in Calcium-K wavelength on 11 Jan 2013 - The active region continues to develop and we have nice weather (although poor seeing) to go with it.
Full disk picture taken with APM 80/480 refractor, with DMK41 camera and Lunt CaK module
High magnification picture was taken with Televue 2x barlow and DMK21 camera
Re: Active Region AR1654
文章David » 2013-01-16, 19:16
The active region in CaK on 16 Jan 2013. Setting things up earlier resulted in much better seeing. The setup is identical to the first post.
文章David » 2013-01-16, 21:49
The active region in H-alpha on 16 Jan 2013, taken with a similar setup to the CaK image but with the Lunt CaK module replaced by the LS100T H-alpha filter. The raw videos were terrible but the final results are surprisingly acceptable after stacking.
文章David » 2013-01-16, 22:01
A high magnification shot of AR1654 on 16 Jan 2013, just for record.
Filter: Lunt Solar Systems LS100F H-alpha filter+B1200 blocking filter
Telescope: APM 80/480 refractor (with Televue 2x barlow)
Camera: The Imaging Source DMK 21AU618.AS
文章David » 2013-01-16, 22:30
Bird-watching with H-alpha telescope 8-)
