Transit of Venus (6 June 2012)
Andy » 2012-06-08, 19:22
LS80T for fulldisk
LS152T for high magnification pics
Poor seeing. :oops:
first fulldisk.jpg (97.24 KiB) 被瀏覽 6140 次
HIGH MAGhighRES.jpg (133.66 KiB) 被瀏覽 6140 次
HIGH MAG.gif6S.jpg (40.99 KiB) 被瀏覽 6140 次
HIGH MAG.gif (1.83 MiB) 被瀏覽 6140 次
Fulldisk X 4.jpg (765.45 KiB) 被瀏覽 6140 次
Andy
文章: 27
註冊時間: 2010-02-08, 23:02
Re: Transit of Venus (6 June 2012)
文章社長 » 2012-06-09, 01:13
暫時香港所見最高水平的攝影作品,也體現了Lunt LS152T的威力 8-)
只是,什麼時間看到動畫便好了.....
文章David » 2012-06-09, 11:30
I think only the egress pics were taken by LS152T. All other pics were by LS80T.
文章willis » 2012-06-10, 14:13
Yes! One can see the differences between LS80T & LS152T. According to CaK's specification, the max aperature supported is 100mm. I guess the safety margin is enough for 105mm. I will try the CaK on 105/650 photographically and see the quality of the image. In fact if one use the CaK for imaging, I guess the aperature could be much larger. That is the margin is only for visual.
