2012年2月 - H-alpha 太阳影像
universe24 » 2012-02-10, 14:29
有效口径才38mm而已。
最後由 universe24 於 2012-02-11, 12:06 編輯,總共編輯了 1 次。
Re: H-alpha 太阳 10.02.2012
文章社長 » 2012-02-10, 15:30
色調有點怪,尤其日珥部份。
具體拍攝數據?
文章universe24 » 2012-02-10, 16:30
色调是Alan Friedman的处理手法,在一次分享会里发现有许多人喜欢这样看太阳,所以就学着做了。
38mm aperture mask + TOA150 + Daystar Ha 0.45A + SBIG STL-4020M
0.12秒曝光
Re: 2012年2月 - H-alpha 太阳影像
文章universe24 » 2012-02-11, 12:07
2012年2月11日
文章David » 2012-02-11, 13:26
universe24 寫:色调是Alan Friedman的处理手法,在一次分享会里发现有许多人喜欢这样看太阳,所以就学着做了。
I like to play with the Friedman style too. Can you share some key steps? I think you just invert the disk, right?
文章universe24 » 2012-02-11, 14:36
Yes. I just invert the disk.
The prominence and disk are process saperately then combine together by layer masking.
I noted that Alan Friedman actually can make the sunspot as dark and filament in bright. Not sure how he do it...
文章社長 » 2012-02-11, 15:46
慚愧,你說到才醒起在哪裡見過,再一次證明自己的心不在太陽觀測上 :oops:
文章universe24 » 2012-02-22, 12:02
2012年2月22日
文章David » 2012-02-22, 19:01
Lots of actions on the sun! I love the prominence on the left which seems to be lifting off into space. The dark filament is also fantastic.
How come I always feel that the CaK image is sharper? Or is it just me..... :roll:
文章universe24 » 2012-02-24, 09:19
You are right, CaK image is sharper.
I have compared two H-alpha filter of the same brand with 0.5A & 0.45A different only.
The one I used (0.45A) never sharper than the 0.5A.
I suspect that my filter is the older production compared to the 0.5A one.
I also noted that the coating of the filter starting to fall off...very similar to what happened on the Lunt BF last time.
文章社長 » 2012-02-24, 11:34
你說的0.45A不是Lunt的吧? 因為Blocking filter的問題只影響一個批次,Etalon不受影響力的:
viewtopic.php?f=19&t=521#p13924
文章universe24 » 2012-02-24, 15:11
不是Lunt的。
不过前两个星期才拜访了已经换过一次Lunt BF的镜主,发现边缘已经开始出现轻微的同样问题,暂不影响使用,再观测一段时间再说。
文章社長 » 2012-02-24, 15:33
若有問題也可再換,他們始終是要解決的。
