三色全太陽 (20100326)
三色全太陽 (20100326)
David » 2010-03-27, 13:21
紅色:Lunt Solar Systems LS75F+APM80/480
綠色:APM80/480+APM Herschel Wedge+Baader Solar Continuum Filter
紫色:APM80/480+Lunt Solar Systems Ca-K Module
相機:DMK41AU02.AS
軟件:Registax 5 + Photoshop CS4 + Ulead GIF Animator
Re: 三色全太陽 (20100326)
文章willis » 2010-03-28, 01:45
When u use the green continum, did u used the ND as well?
文章David » 2010-03-28, 08:31
willis 寫:When u use the green continum, did u used the ND as well?
You must use the ND. The light intensity should be reduced by ND3 first before entering the solar continuum (or any barlow).
文章社長 » 2010-03-28, 08:49
Thanks David for the clarifications.
By the way, would you explain a little bit about which layer of atmosphere we are focus on, by different wavelenghts you image above, hence the different appearance?
文章David » 2010-03-29, 19:40
社長 寫:Thanks David for the clarifications.
I'll add this information when the information is organised enough to post. This won't take long... ;)
最後由 David 於 2010-04-03, 21:20 編輯,總共編輯了 5 次。
文章Lewis » 2010-03-31, 13:46
社長,
其實有一個問題,attach咗圖片後個框框可唔可以大些.
文章wolf123 » 2010-03-31, 19:29
Lewis 寫:社長,
滑鼠指標點下去,就不會有圖片的框框了
wolf123
文章: 100
註冊時間: 2010-02-05, 21:47
來自: TAIPEI
文章社長 » 2010-04-01, 09:10
wolf123 寫:
Lewis 寫:社長,
滑鼠指標點下去,就不會有圖片的框框了
原來是這樣的,學習了..... :oops:
文章Lewis » 2010-04-01, 16:37
wolf123 寫:
Lewis 寫:社長,
滑鼠指標點下去,就不會有圖片的框框了
Thank you, wolf兄.
我時常按右鍵,copy link, new window, 再看.
傻了.
文章David » 2010-04-03, 21:12
Here are some relavant articles:
viewtopic.php?f=15&t=189
viewtopic.php?f=7&t=188
viewtopic.php?f=7&t=187
