19-3-2010 Small scope & big prominence
willis » 2010-03-19, 22:55
The prominence diminished a bit today.
LS35T, DMK41, Stack best 95% out of 200 frames.
LS35T
LS35T
LS35T + TV 5X
Re: 19-3-2010 Small scope & big prominence
文章David » 2010-03-19, 23:37
I probably would not use 5x with LS35F. Even I don't go over 2000mm most of the times with LS100T, otherwise the exposure is too long, and poor seeing usually does not support such high magnifications. Usually, I prefer smaller magnification but sharper image with less exposure time and less gain.
文章David » 2010-03-19, 23:50
I have tried to process your picture. I can give some details later.
文章willis » 2010-03-19, 23:57
Wow! Beatiful! I cannot do it. :oops:
文章社長 » 2010-03-20, 10:53
willis 寫:Wow! Beatiful! I cannot do it. :oops:
人之常情是追求更好的望遠鏡,高分解率、大口徑.....
但Willis你把一台35mm口徑的小日珥鏡的能力很優美地表現出來了 :P
文章David » 2010-03-20, 12:42
David 寫:I have tried to process your picture. I can give some details later.
Some standard tricks are introduced here:
How to process the disk: viewtopic.php?f=3&t=137
How to process the prominence: viewtopic.php?f=3&t=138
How to combine the two pictures: viewtopic.php?f=3&t=140
文章willis » 2010-03-20, 16:19
社長 寫:人之常情是追求更好的望遠鏡,高分解率、大口徑.....
I don't mean that! Just cannot process the image, not the scope...
